-   Volvo XC70 (https://volvoforums.com/forum/volvo-xc70-17/)
-   -   Front Spring Replacement (https://volvoforums.com/forum/volvo-xc70-17/front-spring-replacement-27107/)
glansberry Jan 29, 2009 07:52 PM
Yesterday, I heard an awful sounding noise coming from the left front of my 2001 XC70 when turning, and moving on a bumpy surface. Today in the light, I can see the the spring is broken.
I will need to replace it volvo says a new one is $130.
What else should I replace a the same time? the whole strut?, top mount?
Should I do the right side also?
How hard is this project - I know I need special tools to compress the spring - any other tips?
Thanks
tech Jan 29, 2009 08:20 PM
2 Attachment(s)
WOW on the broken spring. I have never seen a spring break on one of these cars.
I would replace the upper mount while you have everything apart.
You will need a socket like in the picture and a spring compressor. Sometimes you can use a pipe wrench to get the one wacky nut loose. I made my own sockets to remove the nut.
Maybe to the other side mount while you are doing the job.
The job really is not all that hard.
Attachment 23125
Attachment 23126
