Going to clean crankcase vent sys. are these good directions?
http://www.v70xc.com/resources/how-t...g%20Method.pdf
1999 V70XC turbo ???? Also need throttle body cleaning directions. Thanks! |
RE: Going to clean crankcase vent sys. are these good directions?
If it were me for going through that I would just pull the intake and replace the ventbox and clean all the hoses that way.
You can also get to those hoses if you remove the P/S from the bracket without unhooking the P/S lines. To be honest when I have to do it I never remove anything. I have long needle nose pliers and slide the hose off the fitting then blow through the hose. Then use a small piece of heavy wire and clean the banjo fitting with it. |
