help- 2005 xc70 electrical and engine shutdown!
Driving down the road the guages go dead, the engine dies, I
I pull over, turn car off and it restarts right away, its happened about 8 times...any ideas anybody, the dealer has no ideas, been in twice |
I'd check battery first, then fuel delivery.
I'd check all of the ground straps. Battery and fuel system wouldn't affect the instrument panel.
The instrument goes out because the car dies.
Originally Posted by calvinp
(Post 303846)
I pull over, turn car off and it restarts right away, its happened about 8 times...any ideas anybody, the dealer has no ideas, been in twice 1. gauges go dead 2. engine dies 3. engine restarts right away Sounds like a loose ground strap to me. I could always be wrong, however :) |
2005 xc70 shutdown problem
Grounds have been checked, but its very weird, everything seems to die at once, you are driving down the road and you loose power, look down at the guages and everything electical is shut down with the odometer at zero, you coast to the side of the road, turn the car off and it always starts right away with no hesitation....anyone out there heard of this
cal :( |
Similar issue but my car will not die. If I shut off car and restart will sometime solve issues. Would like to figure this one out.
