how to eject ecm?
2000 v70xc
according to vadis, a special tool is required to remove the ecm. is there a way to do it without the tool? i have the housing cover and housing removed. there appears to be a pink slide lock but i cannot move it. i do not want to force anything. |
You have to slide both of the pink things on each side the same. You can slide one side a little then do the other till it is all loose.
Originally Posted by tech
(Post 144254)
I believe they do.
TECH is correct, I did this not to long ago. It is a pain to do it this way but it works.
