How to Remove ABS Module from 2003 XC70?
Hi All,
My ABS module on my 03 XC70 is dead, sending it in to xeMODex for rebuild so I have to remove it. From what I can gather I need an E5 Torx socket, need to remove the ABS fue or disconnect battery prior to starting, and try to figure out how to move the air cleaner so I can get to the unit. Any more specific directions on how to remove my ABS module for this obvious novice would be MOST appreciated. Thanks. |
Turns out removing the ABS module is only slightly harder than changing a light bulb. Sending the module to xeMODex tomorrow, installing rebuild on Wednesday.
Hoping it works. |
