Loose shifter
I have an '02 XC70 and the shifter works fine in automatic except in D the shifter will flop over into the geartronic side. The geartronic works except when you push the shifter forward, it does not return to the center position. I pulled the console off and saw a spring that is loose on the front side of the shifter. On the back side, an identical spring holds a plastic guide in place. This guide appears to be missing on the front side.
My question is, Can this be repaired or must the entire shifter housing be replaced? |
You can repair them the parts are avalible from the Dealer. If they give you a problem let me know and I will give you the part #'s for them.
