Re: climate control unit out after jump start
Hi,
I am the original owner of a 2001 XC and I can't even list all the problems i had with it in the past. It cost me over $5000 and i have just 60.000 miles on it. few days ago my batery was dead and I jump start the car but after that my sunroof, interior lights , climate control unit and the little light by the gear shifter was out. I called my mechanic and was able to "key reset" the sunroof and lights but not the climate unit and gear shifter light. The Volvo dealer recomends new CCM unit for $1300 (parts and labor) and ..."we take it from there". I hope there is a "over load protection" some where...........please let me know if you have any suggestion. Thanks/Rudy [:-][:'(][:@] |
RE: Re: climate control unit out after jump start
Did they pull codes and tell you what they are?
Thanks for your reply.
I got the computer print out which is 5 pages long but says : CEM-1A56 Communication with DIM control modul Signal missing and also No diagnosic trouble codes (DTCs) are stored for DIM, PDM, PSM, SWM. rudy |
I assume the code won't clear?
Did they try resetting the car? |
I do not know if they try to reset the car. they did the "key reset" and that did not work.
Rudy |
They can do an entire car reset with the computer system they have.
Also ask them to disconnect the battery and put the cable ends together for 5 minutes and reconnect the battery and see if that does anything. |
This morning i call back to Volvo and were not helpfull at all.
I will disconect the batery over the weekend and go to them on Monday. What is is exactly I need them to do? The complete reset of the car and reload? Does this operation has a name in there book? They just want me to get the new CCM for $900. here are all the codes from my last visit: CEM 6A02 door unluck, CEM 1A55 comunication with CCM missing , CEM 1A5CUEM signal missing CEM 3F03 shiflock signal missing Thanks for your help/Rudy |
Disconnect the Battery and put the Positive and negative cables together. It discharges all the computers.
Leave it like that for about 5-15 minutes which ever you prefer. Then reconnect and see if it works. The entire reset of the car can only be done by the Dealer. |
Hi,
i did exactly what you suggested and after that i went to Volvo dealer and they reloaded the program in to the CCM and it worked!! Thank you so much for the excellent advice. Rudy |
Congrats glad all is good now.
| All times are GMT -5. The time now is 06:04 AM. |
