Rear Fogs
Is there a way of running both rear foglights? in the uk we have just one
RE: Rear Fogs
In the U.S. we only have one as well.
But if you install a bulb and remove the plastic blocking the bulb from fitting in the light assembly it will work. |
RE: Rear Fogs
Yep.... I helped a friend do just that with a VW Jetta! DIfferent car of course, but same idea/principle.
GLenn |
RE: Rear Fogs
The idea of only one on, is;it standsout like a sore thumb on a crowded, inclimate roadway. Having both on won't look so different.
Also, some may think you have a faulty brake switch or worse they will think you are one of those idiots who ride their breaks. |
