Rumble under car between 20 -30 mph
2001 V70XC 170,000 wife mobile
I do not drive this car often so the Mrs. tells me that the car isn't right. While accelerating from 20 to 30 there seems to be a wheel out of alignment. Front left side with vibration transmitted to steering wheel and under ones right foot. Drive shaft, front axle CV,,any ideas? |
RE: Rumble under car between 20 -30 mph
I would try to remove the driveshaft and see of the vibration goes away.
If not check the tires. |
What do you mean remove the drive shaft?
Also, try swapping the tires front to rear. That is an easy way to tell if it is a tire or something else.
ORIGINAL: ramp What do you mean remove the drive shaft? |
