Stumbling again - Please help!
Old Oct 1, 2007 | 02:28 PM
JavlaBil's Avatar
Default Stumbling again - Please help!
98 XC 70. Had problems about a year ago - changed fuel filter and pcv system - car ran fine for 6 months or so after changing pcv system. Had problems again a few months ago. Changed front O2 sensor - car ran fine for a few weeks. Car began running rough again, finally stranding me by the side of the road. Got it towed home- would crank but would barely pull itself around the yard. Replaced the mass airflow sensor. Now it does fine for the first 3 or 4 minutes. Once it warms up, it stutters and hesitates under acceleration, especially on inclines. You can ease off the gas and then press again and it will surge forward while emitting smoke from the exhaust. Seems to get gradually worse as it gets warmer (haven't driven that far or at very high speeds since i don't want to have to get stranded again). It doesn't appear that I have any vacuum leaks, but i'm not positive. Would greatly appreciate any suggestions! My wife is Swedish and is now on the verge of hating Volvos - and I don't want that on my conscience! :-)
Old Oct 1, 2007 | 06:25 PM
Default RE: Stumbling again - Please help!
Thermostat ok?
ECT ok?
Old Oct 2, 2007 | 05:21 PM
JavlaBil's Avatar
Thanks for the response tech. I don't think i have an ETC - Is there a way to check the thermostat, or shouldI just change it?
I've just been out driving again and it does fine for a bit, then when accelerating or on an incline it stumbles - you can either ease off the gas or floor it and it runs fine, but if you floor it tons of black smoke comes out.
Old Oct 2, 2007 | 06:23 PM
Yes you have a ECT that is the coolant temp sensor.
If the thermostat is bad you will usually see it when you open up the housing.
Does the check engine light ciome on at all?
Old Oct 3, 2007 | 08:35 AM
Psaboic's Avatar
I just had to replace the ECT on our 95 850 and it exhibited similar problems. Granted they are different cars but basically the same engine. Agree with Tech, is the Check Engine light on or are there any codes stored in the computer?
Glenn
Old Oct 3, 2007 | 10:48 AM
JavlaBil's Avatar
Thanks again a ton for the advice. And my apologies for my relative stupidity when it comes to working on cars. When i replaced the mass airflow sensor i disconected the battery for a half hour or so - the check engine light hasn't come back on since then, but i don't think i've driven the car enough for it to do so - only three or four miles. Is it ok to reset the codes this way, or is it better to have them cleared with a scanner? The temp gauge inside the car reads about 1/2 way up, which is the same as it's always been - not sure if that makes a differenence or not. I'll look at the thermostat and check on the sensor also.
Old Oct 3, 2007 | 02:58 PM
JavlaBil's Avatar
Light came back on and I had the codes pulled again.
1. P0131 - Front O2 - low volts (just changed it)
2. P0108 - MAP/BARO - (Just changed Air Mass Meter)
3. P0243 - Turbo/Sup Wastegate - Solenoid A Malfunction
Thanks again!
Old Oct 6, 2007 | 07:34 AM
Did you clear them before disconnecting the battery?
If not then clear them. Just disconnecting the battery won't clear the codes.
Old Oct 8, 2007 | 11:17 AM
JavlaBil's Avatar
Thanks again for posting. I had them cleared - seems to be the same. I've been busy, so i haven't had time to check anything - but I have some time off at the end of the week so i'm hoping to work on the thermostat and the etc. In the meantime, I have been told that it wasn't good that i used an aftermarket O2 sensor. Is this a real problem?
Old Oct 9, 2007 | 08:35 AM
Psaboic's Avatar
I've used aftermarket O2 sensors on cars before. Some are ok, and some are not. While I have not tried it, I have heard that Volvo's do not like the aftermarket sensors and work best with the OEM type.
Glenn
cioara
1998-2000 model year V70
Sep 24, 2014 07:25 AM
badasp5.0
Jun 25, 2008 04:39 PM
crystalfleet
Jan 16, 2008 07:30 PM
ovlove
Jul 25, 2006 12:50 AM
Kruspe31
Dec 13, 2005 09:17 PM
