Timing belt, water pump, tensioner, idler
In the event that the cam or drive shaft move while performing this task. What is plan B. I have done this with my S80T6 and the cam turned one tooth. I was able to correct this after a little guess work.
I have taken all apart after aligning marks on cams and cover. Shall put back together tomorrow. Thanks for any comments. |
RE: Timing belt, water pump, tensioner, idler
I always mark everything before removing the belt.
All went well, I only had to remove the vibration damper to complete the process. Yes, the water pump was leaking.
Glad everything went well.
