Wrapping up tranny swap, starter question:
Are there 2 red wires that connect to the starter post? I neglected to reconnect the wiring for the starter before installing the subframe. I honestly don't recall if I removed one or two from the post. I see 2 fairly large red wires and 1 small wire which I assume is the ground. The small wire is the one which simply slides on the spade type connection.
Yes there are two very large red wires that connect to the back of the starter with that big nut. One of those red wires goes to the positive battery post but it's sort of hard to tell given it is wrapped in that black plastic. I believe the other one is going to the alternator? There is also one small wire that has a plastic insulator covering a connector that connects to the back of the starter.
Thank you for the assistance!
