2.0L Supercharged/Turbocharged - Cam Sprocket Timing Mark Alignment
Old May 6, 2022 | 02:17 PM
suttgartmotorcar's Avatar
Default 2.0L Supercharged/Turbocharged - Cam Sprocket Timing Mark Alignment
Hi,
Hoping for some help regarding the cam sprocket timing mark alignment on a 2016 XC90. We did a top end rebuild and are now trying properly time the engine. There are two plastic protrusions on the underside of the rear cover and notches on both sprockets. Is this the correct timing correspondence?
I have attached a marked up picture.
Thank you for the help!!!
Chris
File Type: pdf
Old May 22, 2024 | 11:01 PM
bclogman's Avatar
Originally Posted by suttgartmotorcar
Hi,
Chris
Did you ever get an answer to your question? I have the exact same issue.
Thanks Brent
frankvftw
Mar 31, 2013 07:20 PM
sparky278
Jan 17, 2011 12:03 PM
ConfusedVolvoOwner
Jul 23, 2009 07:27 PM
ebrobb
Aug 10, 2006 08:25 PM
Osmenthe
Jul 9, 2005 01:36 PM
