A/C doesn't work and it's charged!
Old Mar 7, 2016 | 12:02 AM
rudva's Avatar
Unhappy A/C doesn't work and it's charged!
My XC90 stops cooling, then I recharge the system whit a can from autozone, I used those before in my S40, but this time the a/c compressor doesn't engage right just for short moments, then the air isn't cold
What is it?
Old Mar 7, 2016 | 11:41 AM
firebirdparts's Avatar
Not enough refrigerant.
Old Mar 7, 2016 | 12:28 PM
rudva's Avatar
Default Still in the same
Thanks,
I try more refrigerant, using a can with the meter I leave it in the "filled" zone but still in the same. I already check the relay and fuse, anyway was working well and you always noticed when the refrigerant is finishing after a couple of years.
I'm going to try going to with a guy to check if the psi are the right one or stills not enough.
I let you know guys
Old Mar 7, 2016 | 12:52 PM
vad7000's Avatar
Default A/C xc90
Originally Posted by rudva
Thanks,
I let you know guys
Had the same issue with mine. Ended up taking shims out of the compressor. I got the info from a member here.
Old Mar 10, 2016 | 11:50 PM
arfstrom's Avatar
On a different vehicle, I had used a similar can of UV light freon, and put too much in. There is a sweet spot if you can hit it. It is worth taking it to a shop, (I brought it in on a free A/C inspection)
Old Mar 19, 2016 | 08:00 PM
rudva's Avatar
Free A/C inspection? Wow where is that?
The system was charged in place related with it, now works poor but when I turn on the Rear A/C. Works good, that's mean more gas or has two compressor?
Ruskya Mafia
May 20, 2010 05:17 PM
jchrisf
Sep 28, 2009 09:11 AM
kimpolk
Jul 5, 2009 02:51 PM
bcxs650
Sep 28, 2008 10:04 PM
TacklaNHL
Jun 6, 2008 10:14 AM
