can transmission issues cause -reduced engine performance code?-
2004 xc90 115k miles 2.5 t
everything works great until you get on it to pass and loss of power reduce engine performnace lights up on dash runs like crap pull over restart everything is fine no check engine light engine will rev freely to 5500 no funy noises power brake to 4000 rpm no noises or problems My question can a transmission sensor / problem cause xc90 to basically go in limp mode -reduce engine performance? thanks Jacksonbase |
Sounds like a misfire or a big turbo leak.
Not usually.
| All times are GMT -5. The time now is 08:14 AM. |
