Can you help?
Old Jul 28, 2011 | 09:42 AM
kelsdreamcar's Avatar
Default Can you help?
My XC90 blower motor runs until the battery dies. Started taking out the fuse. After alot of research decided to replace the blower motor resistor. Doing that today. Also, the reduced engine performance light came on about 2 weeks ago. Brought to the dealer, wanted to charge me 1800$ to change the throttle body. Said it was bad. I have a T6 turbo, is the throttle body job to much for one guy to handle in his garage? Thanks!
Old Jul 29, 2011 | 11:20 AM
04XC90T6AWD's Avatar
intresting what codes is it throwing at you? if the reduced engine preformance light is pointing toward the throttle body id take it to a volvo service center its what i do for all my major things i only do oil changes spark plugs and brakes by myself everything else its to volvo i dont bother with these secondary shops either i feel they are inept when it comes to repairing higher end cars such as ours.
Old Aug 1, 2011 | 03:09 PM
bmoore's Avatar
*giggle* You take it to Volvo, right? Except when you plug an AC leak with JB Weld, then dump refrigerant in without gauges? See here: https://volvoforums.com/forum/volvo-...-urgent-55719/
Old Aug 2, 2011 | 10:24 AM
smart *** I used gauges.
Old Aug 2, 2011 | 11:44 AM
agardner's Avatar
Well let me start from the beginning, i had a hole in my A/C condenser and i jb welded that. I took 1 small can of R-134a and emptied it into the unit. Now when i started my car up it makes a whooshing noise and then stops when i click the fan up a speed another whooshing noise is heard each time i up the speed. im thinking it is because the system is not full charged or is it something else? any ideas?
Doesn't sound like you used gauges. Sounds like you stuck some JB Weld onto a high-pressure air conditioning line, then dumped a can of refrigerant in it. That's got the potential to ruin your whole air conditioning system, but hey, it's your car.
Old Aug 2, 2011 | 01:44 PM
when i got the Compressor clutch replaced after it shorted out tech said it was charged to the right setting and was not losing any freon.
Old Aug 2, 2011 | 01:45 PM
guys the hole was barely a pin-hole to begin with
nicolas414
Oct 9, 2024 12:53 PM
patdelamare
2001-2013 model year V70
Jun 24, 2014 12:45 PM
rspi
Dec 5, 2012 12:44 PM
isons2004
Suspension
Mar 29, 2006 10:33 PM
isons2004
Aug 12, 2005 11:57 PM
