-   Volvo XC90 (https://volvoforums.com/forum/volvo-xc90-9/)
-   -   Check Engine Light - P0111 - Intake Air Temperature Sensor (https://volvoforums.com/forum/volvo-xc90-9/check-engine-light-p0111-intake-air-temperature-sensor-79226/)
thegazelle Jul 17, 2014 03:47 AM
Hi there...so my check engine light has come in within the past few days with this code and I had it scanned yesterday...
P0111 - Intake Air Temperature Sensor - Circuit Range / Performance Problem
Anyone know what this is, what may cause this, and how easy (or costly) it is to fix? Thanks. I have an 04 XC90 2.5T with 228,000 KM on it.
Joshinator99 Jul 17, 2014 09:00 PM
The intake air temp sensor varies it's resistance based on the temp it's seeing. If it shorts out or goes out of its normal range I will set a code. You can usually use a multimeter to check it.
karma Jun 27, 2019 08:24 PM
where is the IAT sensor located?
I have a 2004 xc90 2.5T. code says Faulty IAT. I ordered one online from euro whatever. It does not look like anything on my engine. Is there a diagram out there somewhere I can view? I can change it if I knew where it is . thanks for any help
