Child Safety lock and Gas Cap door
Hey guys I have a 2005 XC 90 5 cylinder. It has 78,000 miles on the clock and recently I noticed that the drivers back door will not open unless opened from the outside like the child safety lock is on. The child safety lock switch is not engaged so I'm not sure why it won't open from the inside. Hoping you guys might know something I could check.
Also the little bar that comes in and locks the gas cap door will not engage, so the door can just be opened anytime. Hope these little minor problems are not precursors that something is going wrong. Any help would be greatly appreciated.
if you have the autolock activated ie once you start driving, all door lock, the rear doors will not open from the inside.
2 options
1 - open from outside
2- when you want to let people out from the back, hit the lock/unlock button on the driver or passenger door and they can be opened from the inside
2 options
resolution to door not opening?
I've owned a 2005 X90 for 4 weeks now. Just today, same rear door on driver's side stopped opening from the inside. Has anyone determined a fix to this? Are there some simple things I can check? The passenger's side door appears to work just fine from the inside.
Ok, this is going to sound strange. But on my 2005 XC90 I don't see the Child Safety Lock manual control. It's in the diagram in my owner's manual. But it is not on the door. There are a couple of allen key bolts but nothing else. On the rear gate hatch there is a Child Safety Lock control. But not on either of the rear doors. Has anyone else ever seen this? Am concerned because I just bought this car used a few weeks ago...
2006 XC90 rear door won't open
I have a 2006 XC90. Both rear doors would not open with the inside handle. Not a child safety lock issue as they were not engaged. Not a central locking issue either, I did not have the optional electronic activation for safety locks, The issue was cheap Volvo plastic parts. On both sides the black plastic clip that holds the cable into the door release handle had broken,leaving the cable flapping around inside the door doing nothing. To "repair", you have to pop off the silver plastic cover over the door closing handle--lift it up and then out, I used a putty knife to get it loose. Then take out the two TORX screws that hold the door panel to the door. Then use the putty knife to pop the upper portion of the door panel away from the base of the window about 5 inches, you don't have to release the lower portion of the panel or loosen the handle plastic covering or loosen the window switch.You can see when you look down into the door where the cable is loose and place it back into the notch in the door handle. Make sure it is in right by flipping the door latch with your finger and pulling the inside handle to see it release the latch. If you have it in correctly. take a hot glue gun and glue all the edges of the plastic end of the cable to the handle mechanism. I then put pieces of thin cardboard onto the glued areas with more hot glue to make sure it doesn't pop out again. Then pop the upper portion of the panel back on and replace the TORX screws in the panel to the door. Snap your silver door handle back on and you are fixed.
Old post but wanted to add the same issue. Our '05 shows the Child Safety Lock control in the manual, but they are absent from the door.
berend.vd.molen (05-31-2024)
Cracker39
03-26-2014 08:01 PM
