Do I really need new rotors?
I had a shop put new pads and rotors on the rear of my XC90 about five years ago. Yesterday the same shop says that my pads are at 3 MM and I'll need new pads and rotors at my next oil change. I looked at the rotors and I can see no defects nor are the rotors worn so much that there is a ridge at the outside edge of the disk. Is there any reason why I couldn't just replace the pads?
Thanks
Bill
Thanks
Bill
well are the rotor surfaces flat and smooth? Sure you can put new pads on old rotors but you'd risk a few things 1) the new pads don't bed properly and you lose stopping power 2) the rotors warp as they were actually worn and their thickness was below minimum (you can actually find the minimum thickness stamped on the edge of most rotors should you decide to measure as Sven suggested). My two cents is, pay the $100 for two new rotors, get OEM pads (organic -not semi-metalic or ceramic for long rotor life) and have your rear brakes last another 5 years.
Sven Thorsson (02-25-2020)
