Help. 04 XC90 Won't run, have engine codes..
scanned engine codes with autologic found codes pertaining to the boost pressure sensor and the air mass meter installed both with no positive results. wondering if it might be the throttle body. it will start and run for about 2 seconds and then die, giving throttle will increase rpms momentarily and then die again. any reccomendations??
RE: Help. 04 XC90 Won't run, have engine codes..
Code come right back when cleared?
5 or 6 cylinder? Any spare keys? |
hey... 6 cylinder w/ only 1 key... guys, i need some help on this one. thanks, Greg
