High beams not working...
Hi,
I have a 2007 XC90 (3.2L) and the high beams are not working. I thought it had to be the switch (stalk), but I replaced it with a used one I bought on eBay and no luck. I have no idea what to try next. It's worth noting that while the car was a local shop getting new tires the owner hooked up his "Volvo Computer" that was able to control all sorts of things in the car and he was able to turn the high beams on using his laptop. I was hoping to figure this out on my own before giving up and bringing it back to him. Any suggestions are appreciated. A few notes below.
- The high beam indicator on the dash does not come on.
- All other lights work including the driving lights.
- The blinkers work.
- The bulbs have been tested and are good.
I ran into something similar. It may or may not be your issue but here goes...
I noticed that my high beams don't stay on unless I have the switch in the 12 o'clock position. They flash but don't actually stay on. See the below link for more info.
https://volvoforums.com/forum/volvo-...engaged-29093/
If that's not the issue, not sure. Maybe a fuse? Not sure if there is such a thing but that's where my mind goes next. Good luck!
Have you look at the motor?
https://www.fcpeuro.com/products/vol...r-xc90-8678121
I am sure I have seen it less expensive than this link has it advertised
This was hard to double check, but, here is my double check link.
2007 Volvo XC90 Parts - Niello Volvo Parts
I have the same problem as below and no it’s not the dial on the dash, the hi beams won’t come on at all. I’m planning to replace the 2 fuses that control the driver and passenger hi beams and I will check the motor behind each light, but I find it hard to believe this is the problem when both went out at the same time. The stalk otherwise works fine for blinkers and messages. Is there a relay that I need to check?
Hi,
