Ipod hookup
Old Jun 4, 2011 | 02:44 AM
04XC90T6AWD's Avatar
Default Ipod hookup
is there any way i can get some sort of a hookup installed on my 2004 Xc90. ik there is the Dension GW51MO2 Gateway 500but that is like 400 bucks and i dont have that kind of money i am looking for something that is a bit cheaper. something between an fm transmitter and Dension.
Old Jun 6, 2011 | 05:05 AM
andreasb's Avatar
Sorry, nothing between for the pre 2006 models. FM transmitter or Dension Gateway 500 are the only options...
Old Jun 8, 2011 | 08:42 PM
ckpaden's Avatar
Get a new radio it will cost less and work much better in the long run.
You could look at DICE and I have used them in the past, but it was hardlined into the cd changer. I think I have seen some problems on here with replacing the radio so if you go that way just check it out first.
Old Jun 9, 2011 | 02:58 AM
andreasb's Avatar
You can't just replace the radio. The sound system is a bunch of units spread around in the car and connected by the fiber-optic MOST-network. The "radio" you see on the dash is more or less just a control panel (infotainment control module).
By all means, it's doable, but it's quite a bit of work.
DICE is a Volvo diagnostic tool, I really don't see how that would help.
Old Jun 9, 2011 | 07:23 PM
ckpaden's Avatar
Dice Electronics
DICE Electronics LLC - DRIVE | LIVE | ACCESSORIZE - G2 Cradle
Hummmm, think your confused about DICE, check out the link and you'll find out that this is not Volvo diagnostic tool, if it was it's very popular with BMW, Merc, Audi owners.
Old Jun 10, 2011 | 03:33 PM
andreasb's Avatar
ye....just too bad that "dice electronics" don't offer anything for these cars. In Volvo terms "dice" is usually a reference to Volvo's diagnostic tool - google it.
but, as previously stated, you need an FM Transmitter (which has sucky quality, but cost like $10), a Dension Gateway 500 (fiber optic integration, perfect audio quality, $4-500+install) or get a 2006-> model which already has an AUX-connector.
Old Jun 10, 2011 | 08:08 PM
ckpaden's Avatar
Originally Posted by andreasb
Get a 2006-> model which already has an AUX-connector.
Can you buy a salvaged unit and install it? I've read that people do this with no adverse results?
Old Jun 11, 2011 | 12:02 AM
andreasb's Avatar
No you can't. Not in these cars anyway.
Old Jun 11, 2011 | 12:57 PM
joelq's Avatar
Default Dension's the way to go
I think the best solution is the Dension - which is what I have in my 2004 XC90. I looked into replacing the stock radio with a nice double-DIN 3rd-party radio, but that would have cost roughly the same as the Dension, likely even more if you add all the 3rd-party accessories to integrate with the steering wheel controls and the AM/FM antenna.
The Dension works really well, and I heartily recommend it. Installed it myself in about 30 minutes. There are videos on Youtube that show you how to do the install, which makes it even easier.
Bottom-line, you'll spend at least ~$400 to get your iPod integrated, be it via the Dension or by getting an all new head-unit.
Old Jun 12, 2011 | 12:19 AM
VADIS is the diagnostic tool.... I have figured out a practical solution i just burn CD's b/c A my 400 bucks can currently be better spent for something else B i dont have 400 bucks lying around for something like this. thanks for the help anyway though
Old Jun 12, 2011 | 04:07 AM
andreasb's Avatar
VADIS _was_ the diagnostic software until 2006, when it changed name to VIDA. This is however the software part. The physical tool is called DiCE.
Old Jun 12, 2011 | 09:35 AM
joelq's Avatar
Good deal. I didn't realize your CD player still worked. It was busted on mine, so I couldn't listen to anything except AM/FM. :-)
Old Jun 15, 2011 | 09:17 AM
check out myvolvopartsonline.com or erievovo.com you should be able to pick up just the cd player/changer unit depending on which one you have removal is really easy, i have a few videos of me on my youtube channel. removing the cd changer to take out a jammed CD.
tcoldewey
Feb 12, 2010 09:35 AM
jks2
Nov 22, 2008 10:17 AM
Cleverboy
May 13, 2008 02:44 PM
05S40BE
Oct 25, 2007 11:16 PM
jks2
Aug 26, 2007 01:01 PM
