loose passenger window
I have an '04 xc-90. I went to put down the passenger window yeserday and the window came "loose" and seems disconnected from the mechanism that puts it up and down. I was going to take off the door panel to take a look. Anyone have any tips on the panel removal or the re-attachment of the window? Thanks!
I forget exactly on removing the panel it has been a long time.
But for the window one of the plastic blocks might have broken between the glass and regulator. |
Originally Posted by Vincent12773
(Post 174699)
pry out silver door handle there are two? screws under that handle, and one at the bottom of the panel remove all of them screws pry out the panel from the metal -it is held by clips to the door, carefully remove panel, there is a lock pin in the panel top |
thanks
thanks for the info. It seems completly disconnected. Hopefully it is something i can figure out myself...
complete
:)I removed th epanel tonight and did the repair. You were right about the 2 screws under the handle "cover". The panel came off easier than any I hve worked with before. Found and repaired my problem - the tracks for the motor guides fell off of the bottom of the window. I used some good Urethane sealant, reassembled, and will leave it up for a few days to insure it dries fully.
