-   Volvo XC90 (https://volvoforums.com/forum/volvo-xc90-9/)
-   -   Loud noise that sounds like power steering pump is packing it in (https://volvoforums.com/forum/volvo-xc90-9/loud-noise-sounds-like-power-steering-pump-packing-26006/)
albmm05 Dec 29, 2008 07:20 PM
i have a 2004 T6, has been excellent until the weather caught up with us, -30 celius. We now have a loud noise when the steering wheel is turned at low rpm, and stiff steering at low rpm. On the freeway and highway it is fine. But you can really notice the noise upon slowing down again. my first thought is the pump is crapping out, no leaks normal fluid level. Have not taken to a dealer as I would like to fix it myself. Anyone have any ideas?
tech Dec 29, 2008 08:22 PM
RE: Loud noise that sounds like power steering pump is packing it in
Which type bottle does it have the tall skinny or the smaller square looking one.
albmm05 Dec 29, 2008 09:03 PM
It has the small square looking one.
tech Dec 29, 2008 09:54 PM
Oh ok if it was the other style the bottle might have been bad not sure if the newer ones do the same or not. The metal pipe where the small hose attaches on the top comes out and causes the system to airate and cause noises.
albmm05 Jan 4, 2009 01:07 AM
Thanks for the advice, found the problems which was the hose coming from the resevor, it had a splice by the rad which had let go and is now fixed.
