I need help identifying this part.
In my 2010 seven seats XC90 behind the rear seats are two floor panels which slide against the back of the seats when you fold them in and out.
The edge of this panels is equipped with a plastic "blade" that makes the sliding possible. Without it you manually have to lift this panel before you can set the seat in its upward position.
I'm missing one of those blades and would like to get a new one, but I couldn’t find any part number.
Any help will be appreciated.
Thank you.
I don't recognize that part having spent 14 years with VCNA but I do remember the 2nd row seats having that problem brand new. There is a service bulletin about the part that needs to be updated to correct the issue.
The cause was the lever that gets pushed when you go to move the seat was bend and missed get pushed, you can see it if you look under the seat while someone tries to move it. We just bent it with a screwdriver so it lined up properly, filed a report and shortly after they issued a fix.
Ask a Volvo dealer about Tech Journal TJ32025.1.0-2016-11-28 Seat hard to push back 2nd Row 7 Seater
