Need Hose Identification - On manifold. Vacuum?
Hi All
My 2005 XC 90 2.5T is running really rough at idle and driving. Check Engine light is on with the following codes; P0497 Evaporative Emission System Low Purge Flow P0193 Fuel Rail Pressure Sensor High Input The parts guy says this calls for a EVAP Purge Control Valve replacement. Looking around online it seems that a vacuum hose leak could cause this as error well. Once I started looking around under the hood I see that I have a bunch of really crappy hoses. The one coming from the middle of the manifold is really bad, cracked, almost disintegrated. https://cimg5.ibsrv.net/gimg/volvofo...3919eb3d81.jpg Is this a vacuum hose? What is it for and what is this feeding into (larger rectangle)? I think the ones circled in green are vacuum hoses as well. I cant find any good info. I ordered the EVAP Valve but I'm not sure this is going to do it. It originally sounded like a misfire on one cylinder and that is what I thought I would see in the codes..but that was not in there. Any ideas? Thanks Mike |
