Sponsored by:
Sponsored by:
Replaced battery, now doesn’t start
Old 02-13-2018, 01:45 PM
Springer05's Avatar
Default Replaced battery, now doesn’t start
Replaced battery today due to the previous being dodgy. Initially started up without an issue. I then left the car for the afternoon, when I got back to the car it failed to start... wouldn't crank, ignition lights turn on but nothing happens. A new message had also appeared "transmission service required". I have tried locking, unlocking key fob several times, I have disconnect battery, tried the old battery back in there. All with no luck. Any ideas?
Old 02-13-2018, 07:47 PM
did you check the voltage at the battery terminals? could be you have a bad connection at the posts and not getting enough voltage which can lead to odd error messages
Old 02-15-2018, 11:21 AM
Springer05's Avatar
Default solved
Incase anyone has this problem, the computer had ****ed up and started bringing up loads of fault codes due to changing the battery. Called garage out to my car £50 later faults cleared and it worked again.
bpjtre
07-23-2016 11:56 PM
ctullar
04-29-2013 08:05 AM
CarFreak
09-09-2006 11:39 AM
Quick Reply: Replaced battery, now doesn’t start
