Replacement Key
Hi All,
I recently lost my remote/fob key for my 2005 Volvo XC90. The dealership cost is upwards of $300 for replacement and programing. I've found sites that will sell me a replacement key that needs programming. Can I bring in an aftermarket key and have Volvo program it? Will they do this? Has anyone tried? Are there any other work arounds to avoiding the crazy dealership costs?
Thanks in advance.
Thanks in advance.
Ok,the skinny on Volvo keys.
XC90 after 03 comes with what is called a KIR(Key integrated remote).
There are two parts of this KIR. The actual ignition key,and the remote.
The Key and remote BOTH require software and the vehicle has to be present at a volvo dealer for it to be downloaded.
The Key. It has to be cut to your vehicle,if it is ordered online this would be difficult since hardly anyone would be able to decipher the Volvo keycode and turn it into a cutting program to have a key cut. On top of having the correct key program the correct key also has to be cut.This specific key Bolts to the remote.
The Remote. Is specific in its design to be able to have the key bolted to it.Now,these can be found online,probly all over the place and for fairly good price. BUT,IT HAS TO COME IN THE ORIGINAL VOLVO PACKAGING!!! Not just a ziplock plastic bag with a volvo sticker on it.
The original packaging has a specific serial number and code sequence the service department needs to correctly download the remote. Each remote has a different number.
I hope I have cleared some of this up.If you have any questions,please feel free to PM me.
scoob1 (04-12-2022)
For what it's worth, I had slightly different experience than @Blownby . Mine is a 2010 XC70. I bought an aftermarket key on Amazon for $59 from USAREMOTE. The key looks just like the original, but does not have a Volvo logo on it. I called two dealerships -- the first said they wouldn't try it, the second said they would, but if it didn't work, I'd still have to pay for the software download (which is fine bc if it didn't work, I'd have to buy a new key from them anyways. The packaging was not from Volvo, but did have a bar code and serial number that the dealer was able to use to program it. It worked! They charged $148, so about $210 all together. Much better than the $375 they said it would be for a new Volvo key and $450-600 that independent auto locksmiths quoted me. Short take -- it's worth buying aftermarket and shopping around for a dealer that will try to program it. If it doesn't work, return the $59 and get your money back.
jaimster (09-01-2022)
Another option is to shop a dealer web store like Tasca Parts and buy a genuine volvo part at a discount then pay for the programming only at the local dealer. Not sure how the independent locksmith would get your key programmed short of having their own VIDA DICE - theyd probably drive it over to the dealer for you LOL
What kind of key do you want? Offered are -
The switchblade key, which is a key and remote in two parts bolted together
A rubber handled key and separate triangular remote
A rubber handled key only
A plastic handled key only
All of those require a subscription to VIDA, volvos service program for a download to tell the car to accept the signal from the new key and the new remote if purchased. The stolen/hacked 2014D Vida that everyone talks about and uses Cannot do downloads. Some independents, (or even you can) have a subscription, the dealers have a full time subscription. Subscriptions range from ~$70 for a three day to ~$7000 for a year. The download is maybe $20 each for both a key and a remote, then a labor charge is added for the techs time. It takes maybe 1/2 hour if you are lucky and competent to perform all the steps to program for a new key.
A ebay key needing programming won't do you much good - it will need to be cut also. And there's a possibility of it being copied wrong (I used to have a nice collection of improperly cut keys from the dealer in my top desk drawer at work)
I would order a rubber handled key only from the dealer, using the VIN. (hoping that all the locks have not been changed) That way if it does not turn or is notchy in the ignition or door you won't have to pay for it. Then take the car into the Vida subscription holder of your choice and have the car programmed to accept the new key. The key and the car have to be in the same place as VIDA, it cannot be done (as far as I know) any other way. Cheapest I heard a few years ago was ~$160 from one of my local dealers for a rubber handled key with no remote.
I have never seen a situation where keys have been bought from ebay and the dealer is programming it. Those who got keys from ebay prefer to have locksmith service for key programming.
Instead of hiring a dealer, you can call a local locksmith. They can make a duplicate key for you by cutting a blank key and then programs it properly with the help of special equipment and tools. A locksmith close to your home will give you the best service at an affordable price.
If you order a key from Volvo using the VIN, it's a more exact cut - and you don't have to pay for the key if it does not work.
#17
Hope you get this. I own a volvo c30 2011
I am a compulsive key looser and so far have lost 2 keys in 5 years even with a lanyard and large coin purse tied on.
So I am looking for an alternative and I would like you opinion on whether you think it would work.
1. Use only the actual key to open the door manually
2. Keep a key and programmed fob inside the car secured by a lanyard. It would stay in the car permanently.
3. If I lose the actual metal key then I could have it replaced at I assume, less than 200 dollars.
4. I am not concerned about security issues.
earcuffs (07-15-2021)
#18
laurawilliams-may (06-13-2021)
#20
Mercedes has the ability to cut keys--based on the customer providing the VIN. I'd think that the Volvo dealer should be able to do the same (if they are as much of a group of control freaks as MB) -but I'd be worried if a 3rd party could do this...
