Throttle Body Problems After Cleaning
I'm wondering if I ruined my throttle actuator while cleaning it. I had everything apart to put on a new oil trap so I decided to clean things out. Here are my codes. Your ideas and help are greatly appreciated. I had most of these codes before I did the the cleaning. I have looked at the translations, these are just the ones from my generic scanner. My vehicle is the 2.5L turbo
DTCs (Codes) P1167 MOD $10 No DTC definition found. See service manual CONFIRMED --------------------- P2111 MOD $10 Throttle Actuator Control System - Stuck Open CONFIRMED FREQ REPORTED FIXES 1-Repaired Engine Control Module (ECM) Connector 2-Replaced Throttle Body ALSO REPORTED FIXES 1-Relearned Electronic Throttle Actuator (ETA) 2-Cleaned Throttle Body 3-Performed Throttle Body Cleaning Procedure 4-Cleaned Throttle Body Connector --------------------- P0036 MOD $10 Heated Oxygen Sensor Heater Control Circuit Bank 1 Sensor 2 CONFIRMED --------------------- P2418 MOD $10 Evaporative Emission System Switching Valve Control Circuit / Open CONFIRMED --------------------- P2400 MOD $10 Evaporative Emission System Leak Detection Pump Control Circuit / Open CONFIRMED FREQ REPORTED FIX 1-Replaced Leak Detection Pump (LDP) --------------------- P1167 MOD $10 No DTC definition found. See service manual PENDING --------------------- P2111 MOD $10 Throttle Actuator Control System - Stuck Open PENDING FREQ REPORTED FIXES 1-Repaired Engine Control Module (ECM) Connector 2-Replaced Throttle Body ALSO REPORTED FIXES 1-Relearned Electronic Throttle Actuator (ETA) 2-Cleaned Throttle Body 3-Performed Throttle Body Cleaning Procedure 4-Cleaned Throttle Body Connector --------------------- P0036 MOD $10 Heated Oxygen Sensor Heater Control Circuit Bank 1 Sensor 2 PENDING --------------------- P2418 MOD $10 Evaporative Emission System Switching Valve Control Circuit / Open PENDING --------------------- P2400 MOD $10 Evaporative Emission System Leak Detection Pump Control Circuit / Open PENDING FREQ REPORTED FIX 1-Replaced Leak Detection Pump (LDP) |
How did you clean it?
We used a product by Gum-Out it was called Air Intake and throttle body cleaner. We did have it completely off the vehicle. We sprayed that then scrubbed it with a tooth brush. The part that worried me was that my dad wanted to move the flapper to get some more of the gunk off. I'm wondering if that ruined the motor on it?
Spraying it might have messed it up. You should spray a rag and wipe it and repeat until clean.
You think its a goner or do you think there is any hope of reviving it?
Not sure how you would revive it. Did you clear the codes?
yeah just kind of wishful thinking. I didn't know if I could tear it all back apart and move the flapper back to the close position or not. I know that probably wouldn't fix it either, just more wishful thinking. The weird thing with the codes it wouldn't let me clear 2 of them. I have never ran into not being able to clear some codes. I've also never had my vehicles go into that reduced engine performance mode either. I didn't know if thats what made it unable to clear them or what.
ha!! I just did that. Mines throwing the p2111 code. I can clear it, it runs fine, next key cycle comes back
Originally Posted by Tinysauto
(Post 471521)
