2007 XC90 Radio does not work after disconnecting battery
I have a 2007 XC90 and after i did a little work under the hood (replaced the PCV Valve Cover Oil Deflector, but that's another story). After this repair i disconnected and reconnected the battery as suggested by a video to reset the computer and make the check engine light go off (which it did). since then the radio does not work correctly. IT'S NOT THE CODE. it's not asking me for the code.
When I push the Power button for the radio the screen shows "High Performance Sound " briefly, and a few seconds later, it all disappears.Climate controls/AC work just fine, I can even push the Tuner button and adjust the treble and bass etc. Selecting any of those just goes right back to the default screen. Anyone faced this problem? Any ideas?
I know this is an issue because i've seen it described in other threads and locations online but i haven 't seen any solution. has anyone else seen this issue resolved anywhere?
big daddy russ
03-31-2016 07:56 PM
