Where is the Water?
Where is the Water?
I have read about all of the possible causes for water leaks in my 04 xc90 t6. I do have water somewhere in my car and I can hear it sloshing when I come to a quik stop, but I can't figure out where exactly it is and how to get it out.
It sounds like it is under the driver side floor or close by. And it sounds like a lot of water. I looked under the car and found some rubber plugs but when I pulled them out it was dry inside. also after checking the sunroof tubes and finding them ok, I don't know where else to look for leaks. My carpet is not wet but after a drive or overnight the inside of the windshield is all fogged up. I really need to get this figured ou because I'm afraid that the car will rust badly from the inside.
Thanks for any input
Jim
Jim
It generally happens when the sunroof drains get clogged they back up into a spot underneath the floor mats.. Once you car hear it sloshing.. Quite a bit of water is under there. Get it fixed pdq before you start having electrical problems. Also do a search for sunroof problems/leaks on this board.
