Xc90 15- wiring diagram OEM hitch and rear heating seat
Hello,
I'm trying to find wiring diagram for xc90 2017 for swirl hitch and rear heating seat. I buy already some pdf but there's only engine, ABS and some other things. There's no hitch and heating seat, maybe some one can share or sell pdf with wiring diagram? ThankxLux333 |
What is your VIN number?
Yv4a22pk0h1153028
What trim level xc90 is it? I don't see any diagrams for rear heated seats only the front.
It's Momentum. Xc90 for sure had rear heating seat. I wanna do a retrofit.
With that vin number and inputting the correct trim model I still am unable to access any heated seat wiring diagrams for the rear seats. I have an XC90 myself and it has no rear heated seats only front.
Could you check this one YV4A221L3L1556253? It's Inscription and that one for sure have rear seat heated.
Originally Posted by Lux333
(Post 523568)
I tried to upload it as a pdf file but was unsuccessful, so just printed the wiring diagram off and took a picture. If you zoom into certain areas you should be able to read it pretty clearly. If I can find out how to upload pdf direct from website would be a lot better. Anyway hope this helps. |
Yes, that's enough for sure, thanks a lot. Do you have also wiring diagram for swirl hitch?
It's possible to get also wiring diagram for retractable trailer hitch?
(Post 523724)
So, I have to find a VIN with trailer hitch?
Hi, finally I found some VIN's with swirl trailer hitch.
YV4A22PK1L1600880 YV1LC68BCH1126526 YV1LEA89GJ1478861 Could you check if you have wiring diagram for hitch? Thank you |
