XC90 Loud gurgling, vibratory sound at high speeds, P0192 and P0193 CEL codes
Hello all, any and all advice is greatly appreciated.
I have a 2011 XC90 AWD 3.2 liter. it has 104,000 miles on it. I have a check engine light on and went to read the code and it comes back P0192 - Fuel Rail Sensor A and P0193.:(:(:( I am going to bring the car into the shop on friday, but wanted to get input from this community as to what may be the issue. Additionally, when I am driving i get a loud vibratory, almost acoustic sound or when i am up to speed and either driving straight or slightly right. :confused::confused::confused: the sound goes away when i am turning left. I am not sure if these two issues are correlated. :confused::confused::confused: Thanks in advance, Marlon from Philly |
The fuel rail sensor is easy. The noise you are describing sounds like a front wheel bearing. also, not too bad.
I was experiencing similar sounds when accelerating from 1rst to 3rd gears. Ended up being a couple of worn pulley wheels on the engine and worn mount bushings on the torque arm which is on the passenger side of the motor connecting it to the strut tower.
