850 headlamp options.
well i have a hole in my driver side headlight.
what are some options i have as far as aftermarket? is anyone using aftermarket headlamps? any pics? also, where is a good place to buy online? |
RE: 850 headlamp options.
1. Search the forum. Especially the VolvoForum Resources Thread in the General Volvo part of the forum.
https://volvoforums.com/m_38606/tm.htm 2. Your options are as follows... a. Keep it stock b. Install E-code headlight lenses and turn signals c. Or buy the 850 Chrome or Black Jewels. Which is a complete headlight housing's and lens's and turn signals. These are your only options that you have. |
oh thanks!
Pictures
1. E-codes http://www.eurosporttuning.ca/images...180-102-T1.jpg *These are the turn signals http://www.eurosporttuning.ca/images...280-101-T1.jpg *Those are the headlight lenses. Yeah they might not look different then your OEM DOT lenses however they are different. Much differen't beam pattern then your DOT lenses. 2. Chrome and Black Jewels http://i20.ebayimg.com/04/i/000/b6/f1/e0a1_1.JPG http://www.partsforvolvosonline.com/...4507_large.jpg *These are the Chrome Jewels http://images.channeladvisor.com/Sel.../3/8508203.JPG http://www.partsforvolvosonline.com/...4508_large.jpg *These are the Black Jewels. |
thanks! looks like ive got some thinking to do
For those of you that read this later and ask about projector headlights. There are none made for the Volvo 850 models.
If you want projectors you will have to do a custom Projector Retrofit. |
is it possible to just buy the plastic part? like jut the lens? or do i need to buy the entire housing?
ORIGINAL: wannaseemysocks is it possible to just buy the plastic part? like jut the lens? or do i need to buy the entire housing? With the Chrome and Black Jewels it is the whole kit. |
| All times are GMT -5. The time now is 02:17 AM. |
