850 left corner headlight popped out
I took my poor baby over a speed bump a little too hard and my left side corner light popped out. The wiring wasn't disconnected so the signal still works but the casing is dangling on my fender.
I looked at the right side corner light and see there is a spring/coil that connects the casing. On the left lens case the plastic broke off and the spring is gone. None of the local autopart stores carry the casing so I gotta order online. Soo question is if I buy this online will the coil/spring come with the lens casing? |
RE: 850 left corner headlight popped out
Some do some don't. Check with the company.
on the top corner of the headlight facing the fender. there is a screw. that screw keeps the corner light from falling off. so all you need to do is unscrew that one screw and you just pop the light right off. its held on by a ball cup thing that is connected to the headlight. it takes like 2 minutes to take off and put back on. its really that easy. :cool:
__________________________ Check out: Discount Volvo Parts |
ORIGINAL: khooper on the top corner of the headlight facing the fender. there is a screw. that screw keeps the corner light from falling off. so all you need to do is unscrew that one screw and you just pop the light right off. its held on by a ball cup thing that is connected to the headlight. it takes like 2 minutes to take off and put back on. its really that easy. :cool: __________________________ Check out: Discount Volvo Parts |
