Wheels, Tires and other Exterior Talk about your rims, body kits, and other exterior mods here.
2008s60 awd
Old 03-04-2018, 11:56 PM
Pralph71's Avatar
Default 2008s60 awd
Have a question will 17 by 8 pegs fit o8 s60 non r with 49 mm offset stock with 235 45 17.5 by 49
Old 03-05-2018, 12:16 AM
Pralph71's Avatar
Default Love my awd
Hi my name is pete I own 08 volvo s60 awd love my car but have few issues try in to resolve
Old 03-16-2018, 01:54 PM
Welcome to Volvo Forums Pralph71
I'm guessing you're lack of response might be you're posting in New Member and not in "Wheel and Tire" or the "S60" so this will get moved.
Old 03-16-2018, 09:00 PM
you can research wheel bolts/center bore/offset by using wheel-size.com and comparing models. Generally speaking Volvos from the 850 through the S60 line are 5x108 with a 65.1 center bore so the Pegs should bolt right up. As far as offset goes, you need to check what the Pegs are since they may be OEM or they may be aftermarket. You'd need to look for the ET number stamping. You'd want something in the 43-46 range to account for the extra .5 inch rim width - to keep the extra width more torward the wheel arch.
LarryNH914
03-05-2018 12:11 AM
joker
09-07-2016 08:41 AM
awdMN
11-28-2010 09:08 PM
shrekthefearless
12-26-2008 10:42 PM
Quick Reply: 2008s60 awd
