-   Wheels, Tires and other Exterior (https://volvoforums.com/forum/wheels-tires-other-exterior-27/)
-   -   Tire size question for S60R (https://volvoforums.com/forum/wheels-tires-other-exterior-27/tire-size-question-s60r-13644/)
AhDoi Sep 7, 2007 12:10 AM
Anyone run 235/50/18 or 245/40/18 with any issues?
TheSteelKnight Sep 7, 2007 04:01 PM
RE: Tire size question for S60R
I have the18" rims on my S60 R. there is a little tire rub, but you can control that.
AhDoi Sep 7, 2007 07:16 PM
I have 18" rims too but what I'm asking is about tire size. 245/40/18 or 235/50/18. Is this ok on the R's?
TheSteelKnight Sep 7, 2007 10:06 PM
I would always go with what comes from the factory. you know it will work then which i believe are the 245/40/18's
AhDoi Sep 8, 2007 03:05 AM
Actually the factory specs are 235/40/18. It has been said that even with factory, there can be some rub when you turn your wheel all the way to one side.
The reason I'm even considering 245/40/18 or 235/50/18 is because someone is selling a used set of snow tires and I'd like to see if it'd be ok to use them.
ExTuscani S60R Jun 12, 2013 04:54 PM
Hello AhDoi. My S60R have four 245/45R18 Dunlop Direzza with no rub issues. It will rub only when you are in reverse and turn a lot the wheel.
Other than that not rub at all :)
