Signature picture??
I just copied and pasted that from your other post and it worked just fine.
Post that in your signature area and it should be good to go.
I also copied and pasted it into my signature and it works. Try it yourself. Once you have it working I will take it out of mine. I am leaving it up to show you and others that it works.
Also if I am not mistaken I see INSERT SIGNATURE PICTURE. Now I don't know exactly what that is, but I have a pretty good idea that if you clicked it after you uploaded your picture that it would probably insert the picture into your signature.
Use this link for your image file http://img32.imageshack.us/img32/3194/volvocopy.jpg
Follow the picture step..
WHat is your "Message Editor Interface" setup to?
got to "USER CP" at top of the page, then click on "edit options", then scroll to bottom under "Miscellaneous Options", then use the box to select enhanced interface - full WYSIWYG editor
