NOS Volvo parts
Old 04-21-2017, 03:17 PM
je67's Avatar
Default NOS Volvo parts
I picked up some NOS parts (with a few used ones - noted below) when buying some 544 parts. If you are interested in any, please contact me. I am open to offers on any of them. Paypal for payment and tracked/insured shipping only to protect both buyer and seller. Sample pictures of some parts but I will send pictures of anything you want detail on. Please ensure proper fit for your application.
qty part # description
1 9442047 trip computer
1 9148572 clock and temp sensor
1 9441029 used fuel pump relay
1 1378076 cruise control relay
1 9442934 used cooling fan relay
1 1348129 central locking relay
2 9148482 drivers door relay module
2 9148765 passenger seat heater switch
2 9148766 drivers seat heater switch
1 261230018 Bosch MAP sensor
3 3523120 rear window switch
1 1347764 overdrive relay
2 6849808 headlight switch
1 9148600 traction control switch
1 9148483 power lock switch
1 9128538 driving mode switch
1 9162467 dash light dimmer
1 9125204 hazard switch
1 9128543 info reset switch
2 6849422 power window/ mirror switch with harness
1 1390903 vacuum booster
1 390206926 wiper motor
1 004538 cruise vacuum servo pump
1 9140773 abs control module
1 9162968 turn signal switch
1 9162967 turn signal switch
1 3523207 wiper switch
1 3547699 crankshaft position sensor
1 271598 left outer tie rod
1 9181371 trans shift cable
1 3546483 trans shift cable
1 6.298.1327 clock spring no. 0962
2 221601012 coil
1 1235522408 bosch dist cap
1 9146505 cruise pedal switch
1 44049327 sun roof motor
1 6846567 lock kit
1 3512938 used trim moulding right
1 3512937 trim moulding left
1 3512938 trim moulding right
1 1271892 throttle body
4 9140405 wheel cap
1 9178600 sill molding
1 9178601 sill molding
1 6849410 used speaker
1 6849318 used dash control
1 9152529 used hood lock
1 3501322 fuel pump lock ring
25 6806505 clip
1 9186486 water temp sensor
1 6842536 pressure sensor
1 9445258 ignition cable
2 6806297 rear door edge lens
2 9133824 wiper blade
2 bosch headlight wiper arms
1 580453420 fuel pump w screen and clamp
1 9135032 timing belt
2 9186352 serpentine belt
1 control arm 313 R a 21 253 97
1 258003593 o2 sensor bosch 4 wire
1 258005062 o2 sensor bosch 4 wire
1 9181154 solenoid
1 9168039 speed sensor
1 9146108 used cam sensor
1 9142957 fuel pump
1 9180729 fuel sender
1 9134398 lh fog lamp retainer
1 9134399 rh fog lamp retainer
1 90.605.04.347 ****
6 3515067 sealing ring
2 1372615 trunk lid stop
2 pa6 30 gh plastic vent?
1 6806030 plug
1 1390159 cover washer
1 20244 fender emblem
1 1372870 reading lamp
1 9128420 plug
4 9151139 wiper deflector
2 under hood lights? No p/n visible
1 974683 12mm grommet
1 pa6+30gf unknown plastic 1882
2 3512998 trunk lift support
1 9187796 trunk lift support
1 3509350 trunk lift support
2 9174640 seat heater
2 6806479 seat heater
1 9135047 pre heating plate
2 9173368 shock
Attached Thumbnails NOS Volvo parts-100_4532.jpg   NOS Volvo parts-100_4540.jpg   NOS Volvo parts-100_4545.jpg   NOS Volvo parts-100_4552.jpg   NOS Volvo parts-100_4565.jpg
NOS Volvo parts-100_4566.jpg   NOS Volvo parts-100_4567.jpg   NOS Volvo parts-100_4568.jpg
je67
08-28-2017 07:59 AM
je67
04-22-2017 01:27 PM
Cubic_Curiosity
08-18-2015 11:44 AM
andre4999
10-14-2012 08:20 PM
bastardbus
10-01-2011 10:17 AM
Quick Reply: NOS Volvo parts
