Air conditioning is not working correctly
Old Nov 4, 2008 | 07:03 PM
  #81
Default RE: Air conditioning is not working correctly
I hope it works!!!
Old Nov 6, 2008 | 04:10 AM
  #82
axelm's Avatar
Now this is really strange. If I press the brakes, the compressor disengages.
For example:
- I start the car, engine is cold.
- Tranny in neutral
- Parking break is on
- I switch on the A/C, air is nice and cold.
- The driver´s window is open so I can hear the compressor
- If I press the brakes, the compressor stops working.
- If I release the brakes, the compressor starts working again.
Same thing happens if I press the brakes for a stop light, a curve or a speed bump.
This does not sound like normal behavior. There must be a Gremlin inside the engine cabin eating wires, lol.
Old Nov 6, 2008 | 07:53 AM
  #83
How much other stuff did he rewire?
They are in no way connected. Yes it is VERY weird.
Old Nov 6, 2008 | 08:14 AM
  #84
axelm's Avatar
He split the signal coming from the low pressure sensor to the ECU and connected that wire to the aux relay. He also changed the low speed ground input signal on the fan relay so it would take input from the new relay. Nothing else.
Maybe there is an electrical problem generated by the brake lights. The rear fog light fuse is blown, and very frequently I get the yellow lamp indicator on the instrument cluster. Gotta check out the wiring thoroughly. Maybe something is affecting the compressor relay in the glove compartment.
Old Nov 6, 2008 | 08:23 AM
  #85
Maybe the way he tapped it in is making the computer think when on the brakes you are actually at full throttle and that is why it is kicking off.
Just a theory but still cannot see how they are related.
Old Nov 6, 2008 | 08:38 AM
  #86
axelm's Avatar
I am inclined to think there is another problem, probably related to the relay in the glove compartment.
Old Nov 6, 2008 | 03:50 PM
  #87
Possibly I have never seen that before either.
Old Dec 15, 2009 | 03:01 AM
  #88
jainkelly's Avatar
Default air conditioning Parts
Mobile Air Spares is one of the leading company in Cab-Aire spare parts. Mobile Air Spares provide spare part for all commercial vehicle air conditioning parts throughout Australia.
mobile air conditioning Parts
Old Jul 20, 2010 | 07:22 PM
  #89
Taz-Hornet66's Avatar
Thanks folks been having this problem and didnt want to take it to the shop for something minor.
Old Jul 20, 2010 | 09:28 PM
  #90
850_96's Avatar
god thats weirder then mine
Old Jul 21, 2010 | 12:21 PM
  #91
Rosew6211's Avatar
My 96 850 did the same thing. Caught a thread on checking to see if the magnet clutch is pulling the clutch to the compressor drive all the time. With ac on and set at lowest temp. setting, and clutch spinning, take a broom stick( careful of fan blade) and push lightly against the face plate of the compressor. If the face plate jumps in and clutch starts driving compressor, then there is too much clearance between the compressor drive and clutch plate for the magnet to pull the two togather.. There is a simple fix that worked for me now well over a year. Working from underneath, check the gap between clutch and compressor drive wheel. should be 20/1000 inch or less. I pryed up the tabs on the clutch plate(4) cleaned under each well with soap/water. blew dry, and then using epoxy, I placed a small piece of 30/000 inch thick formica under each tab, finished side towards tab, rough side down with small amount of epoxy on it (don't get the epoxy on the tab side.) This put my gap well under 20/000 and the fix works fine. Beats removing the compresssor and tearing apart. Took me about 1 hour for this fix at essentially 0 cost.
axelm
Jul 18, 2017 12:45 AM
Alun J
Apr 20, 2015 01:18 PM
volvoguy2323
Jun 24, 2010 03:10 PM
Media
Apr 7, 2010 12:13 AM
azeezn
Jun 24, 2006 05:54 PM
