more tech questions please help?
Old Dec 19, 2004 | 06:49 PM
knight rider's Avatar
Default more tech questions please help?
I was thinking of a couple other mech. problems I have had. Rarely when I am driving on the highway, the engine won't accelerate. Sometimes I get a pulse in the acceleration. 1 or 2 times, the car just dropped to idle and pressing the gas pedal did nothing. I have been told it may be something with the electronic throttle control. once the car actually shut off. I was cruising down a long driveway. I tried to restrt several times and it would only run for a sec or two. I then put it in neutral and revved it up when I started it. it revved up and dropped down to idle. I then put it in gear and fine ever since. I noticed once or twice it also wouldnt accelerate at high speed. Goin 60 I tried to accelerate and the rpms climned up, but no accel.
Old Dec 19, 2004 | 07:16 PM
Default RE: more tech questions please help?
I am assuming you have an 850 so you don't have an electronic throttle system.But sounds kinda like the transmission is slipping.Do you have any check engine light or trans arrow flashing?
Old Dec 19, 2004 | 07:17 PM
no trans light. What about the fuel filter?
Old Dec 19, 2004 | 07:19 PM
I forgot to add that it doesn't seem to me that it would be the trannie with the loss of power and the throttle not reacting with it remaining at idle. i do agree that it sounds liek tranny with the revs and no pull.
Old Dec 19, 2004 | 07:21 PM
You said in your last post the rpm's would go up but the car would not accelerate.That is why I say the trans might be slipping.
Old Dec 19, 2004 | 07:27 PM
I agree, but i think there are two seperate problems. Sometimes the car will be driving and will just drop to idle and when I step on the gas nothing happens. And the pulse I referred to is the same thing only very fast and repeated. When I have the other problem with no available power, i step on the gas and it reacts with higher revs, but know increase in acceleration. Does it sound like they are both caused by the trans.
Old Dec 19, 2004 | 07:32 PM
The no throttle response might be a bad mass flow sensor or fuel pressure dropping after the pump gets hot.The trans slipping is another problem.
Old Dec 19, 2004 | 08:00 PM
Ive had to replace the air flow sensor before, but how do I fix the fuel pressure drop if that is the problem? Will these problems show up in code if I hoked up a diagnostic check?
Old Dec 19, 2004 | 08:06 PM
The fuel pressure will not show up with a code.Sometimes the mass flow sensor will.If you have a fuel pressure guage hook it up and try to set it by the bottom of the windsheild.drive the car like normal and when the problem comes up look at the guage and if the fuel pressure is not where it is supposed to be it will need a new fuel pump.
Old Dec 19, 2004 | 08:25 PM
Makes sense...... I just went to the grocery store and my check engine light and service light were on, but my abs and trac light were not. As I started drivin, I felt the abs kick in and make a noise then the lights came on. After goin about a mile or two, the service light went off, but check engine was still on. It looks like a Christmas tree in my gauge cluster.
Old Dec 20, 2004 | 09:52 AM
Now you still have 2 diffrent problems.The check engine light.The ABS light which is probably a bad ABS module.The check engine light you have to pull the codes to see what is wrong.The service light is just an oil change reminder.If your car is 95 or newer you will have to find a scanner to pull codes.
http://home.earthlink.net/~vicrocha/...vo_V70_ABS.htm
follow link for ABS module rebuild company.
I just noticed in another post your car is a 1994 follow this link for engine codes and how to pull codes.
http://www.troublecodes.net/Volvo/
Old Dec 30, 2004 | 12:11 AM
The problem ended up being a bad o2 sensor and knock sensor. steering was bad tires, bad tire rods, and bad stabilizer end link.Not too bad. Easy 1 day project
Old Dec 30, 2004 | 01:11 AM
Glad to hear you got it fixed.
gordon368
Jun 6, 2009 03:01 AM
dragonz
Nov 9, 2008 08:29 PM
1996850turbo
Aug 26, 2008 07:44 PM
harstonsharley
Mar 23, 2006 10:42 PM
