Finally Got my 95 850 Turbo wagon home today
Old Feb 6, 2010 | 09:15 PM
  #41
91shelby's Avatar
Finally got it running today, one of the sensors was plugged in though now it wont stay running but will rev up and is smoking out the exhaust a lil and blowing oil from the turbo so i think the turbo seal has gone bad any idea why it wont idle though?
Old Feb 6, 2010 | 09:27 PM
  #42
Maybe the Mass Flow sensor is bad.
Can you pull any codes?
If you do not know how to pull the codes see link below.
http://www.troublecodes.net/Volvo/
Old Feb 6, 2010 | 11:27 PM
  #43
91shelby's Avatar
alrighty well its throwing codes 535, 314, 122, 121, 213, 214 which seem to be mostly sensors should i reset it?
Old Feb 6, 2010 | 11:39 PM
  #44
Clear them and see what comes back.
The main worries are the cam sensor,crank sensor, and MAF.
All 3 will stop it from running or make it run crappy.
Also if the MAF is bad you can unplug it and start it. If it then idles and will not if it is plugged in the MAF is bad.
Old Feb 7, 2010 | 01:18 AM
  #45
91shelby's Avatar
also is it normal to have a bit of oil underneath the spark plug wire cover?
Old Feb 7, 2010 | 08:30 AM
  #46
Well it depends. If someone spilled oil filling it up then yes. But it could also be a leaking cap seal or plugged vent system.
Old Feb 7, 2010 | 02:42 PM
  #47
91shelby's Avatar
well it looks like there is a new oil filler cap in the back seat. Does those oil symtoms sound like a bad seal in the turbo?
Old Feb 7, 2010 | 02:47 PM
  #48
Nope on a bad turbo seal. I would clean everything up really good and take it for a drive and then recheck.
Old Feb 7, 2010 | 05:57 PM
  #49
91shelby's Avatar
i will do that also any ideas what else it could be all the plugs look good, i highly doubt its the rings. coud plugged pcv system do that as well?
Old Feb 7, 2010 | 06:18 PM
  #50
Clogged PCV will make oil come out all over.
But for running unplug the MAF and start it. If it idles good the MAF is bad.
Old Feb 7, 2010 | 06:21 PM
  #51
91shelby's Avatar
as well as cause it to burn oil too?
Old Feb 7, 2010 | 06:24 PM
  #52
Yes it will.
Old Feb 7, 2010 | 07:03 PM
  #53
91shelby's Avatar
well i got it to idle but it idles low and if i rev it up and let of itll stall
Old Feb 7, 2010 | 07:08 PM
  #54
Is that with the MAF unplugged?
You might also need to clean the throttle body and idle motor.
Old Feb 7, 2010 | 07:45 PM
  #55
91shelby's Avatar
thats with the maf on after i reset the comp before i reset it with the maf unplugged itd idle for 30 secs then die off
Old Feb 7, 2010 | 07:55 PM
  #56
Oh ok
Old Feb 11, 2010 | 10:24 PM
  #57
91shelby's Avatar
also how do i find the engine code?
Old Feb 11, 2010 | 10:55 PM
  #58
91shelby's Avatar
also im having a hard time finding an intake manifold gasket, as i need to clean my pcv system but i need to remove the intake
Old Feb 11, 2010 | 11:01 PM
  #59
TIPSP's Avatar
Got Boost?
Check http://www.fcpgroton.com/
or http://www.ipdusa.com/
for gaskets...etc.
Old Feb 11, 2010 | 11:17 PM
  #60
91shelby's Avatar
what about finding the engine code
