throttle control
Old Feb 20, 2005 | 11:06 PM
reg's Avatar
reg
Default throttle control
Tech...............does a 2001 c-70 coupe have electronic throttle control (drive-by-wire)?
Old Feb 20, 2005 | 11:24 PM
Default RE: throttle control
Everything 99 and up have the electronic throttle body's.The only car that doesn't have it is the S40 that still has a cable up to 2004.The 2004 1/2 has the electronic system.
Old Feb 21, 2005 | 10:50 AM
reg's Avatar
reg
Is the electronic system prone to failure? Recently I heard that it was an issue and to correct the failure was quite costly. Correct?
Along that line, what is the most common failure "part" to the c-70 and is there a time/mileage element involved?
Thx, Reg.
Old Feb 21, 2005 | 10:57 AM
The 2 main failure items on the C70 are the throttle body and the Window regulators.Both are pretty expensive to have repaired.
Old Aug 19, 2006 | 02:49 PM
c70turbogt's Avatar
Tech....
whats the recourse today on a failed ETM for my 99 hpt c70. I got a recall on it. What are the steps that c70 is warriented under in the recall. Is it just reprogramming or are there 2 more steps. I have heard they should clean it and replace it as the remaining steps if the first or second dont work. I have also heard only the programming is under warranty. please clarify...
thanks much
Old Aug 20, 2006 | 10:54 AM
They should clean it and install the Download for the Upgrade.
Then is that doesn't work they replace it.
It should all be under Warranty.
smerdakof54
Mar 18, 2017 03:44 PM
Beau98
2001-2013 model year XC70
Feb 8, 2015 08:30 PM
MFHull
Oct 9, 2014 09:01 AM
treestone27
Apr 29, 2014 07:40 AM
ijourneaux
May 29, 2011 06:30 PM
