S60 D5 Loss of power DTC P0244
Old Apr 17, 2005 | 05:56 PM
WHYAYEGTI's Avatar
Default S60 D5 Loss of power DTC P0244
Thanks for reading my post.
I have a S60 D5 2.4 td and when driving hard through the gears the car seems to loose power as though it is hitting some kind of fuel cut.
I have read the ECU and the DTC stored is :-
P0244 Turbocharger Wastegate Solenoid (A) N75 Range/Performance
Does anyone know the location of this valve?
Can you clean the valve?
any info would be brilliant.
Gavin
Old Apr 17, 2005 | 08:00 PM
Default RE: S60 D5 Loss of power DTC P0244
Find the turbo unit and you will see the wastegate and the wastegate Valve you can follow the hose back till you find a valve like setup.Sometimes it is mounted on the side of the air box or very near it.
Wesley brown
Oct 7, 2014 10:12 AM
kevind
Dec 20, 2011 10:34 AM
SullyS60
May 19, 2010 12:40 PM
jakesullysavatar
May 18, 2010 09:28 PM
hoodoo262
May 15, 2010 04:49 PM
