Welcome to Volvo Forums!
Welcome to Volvo Forums,
Old 01-01-2008, 12:29 PM
tech tech is online now
Default 850 Seat back cable repair
This it how you repair the seat back cable. I will also explain how to replace the cable as well.
You will need to remove the Lumbar adjustment knob. Unscrew as far as you can. Then pull out and unscrew till it stops then one more time pull and unscrew. The washer part under the knob pulls right off. It will look like this.
Then you will need to cut the 4 metal hogrings in the seam where the front and back of the leather meet.
Also you will have to remove the seat switch panel. When you do so on the back of the panel there should be a red plastic clip. Install that where I have shown in the picture. Failure to do so may cause the seat air bag to go off if that metal piece is hit while messing with the seat. If your clip is missing find something plastic fairly thick to install there.
Sometimes it is easiest to get to them from the back seat area.
Next unfold the leather from the plastic pieces on the ends. There is little hooks that hold the leather.
Next start sliding the leather up the seat back slowly and carefully. There is 4 more hog rings you will need to cut. In the picture they are located in the little holes you see where the metal rod is. They go around the metal rod in the leather and to the rod in the foam.
Also while sliding the leather up you will have to unhook little hooks from the back side that help keep the leather tight around the rear pocket of the seat.
The white stuff in the middle is the heating element for the seat heaters.
Once you get the leather this high look from the back of the seat. You will see the motor and transmisson.
If you choose to try to repair the cable you will need to heat the metal in either the transmission or motor and slide the plastic parrt of the cable in. Then while holding it move the switch and make sure the cable grabs. Sometimes you will have to do both sides at the motor and transmission. I had to do both on both of my cars. I did this today thats where this post is coming from.
Before repairing the cable.
After repairing the cable.
Before repair at transmission
After repair.
If you want to replace the cable you will have to slide the big plastic piece off the inside to remove the screws holding the transmission to the seat. Also remove the clip on the rod to slide the transmission out to gain access to the screws to remove the cable. Remove the screws in the motor from the retainer to get the cable out and replace the cable.
Install everything in reverse order.
Hope this helps someone out there.
FYI this is a picture if hog ring pliers and a hog ring.
__________________
1995 Yellow T5-RM yes Manual
1996 850 turbo
Old 01-03-2008, 04:21 PM
elchingon2002 elchingon2002 is offline
Default RE: 850 Seat back cable repair
Thanks for the great write up!
I did this job once about 2 years ago but I didn't know about your trick to reuse the existing cable by shortening the plastic cable sleeve. What source of heat did you use to melt the plastic cable sleeve? (i.e., electric heat gun, soldering iron, butane torch?)
I have to do this to my other 850 and I'd love to know how you did that without burning the seat foam.
Thanks!
__________________
1995 Volvo 850 Turbo / 1997 Volvo 850 GLT
Old 01-03-2008, 06:16 PM
info2x info2x is offline
Send a message via AIM to info2x
As always a great writeup tech.
I couldn't find my hog rings this summer so I just used Zip-Ties, can't tell the difference.
[align=left] [/align]
__________________
http://secretweapon.sslpowered.com/external/Sig.jpg
1994 Volvo 850 "The Chiseled Brick"
1991 Volvo 245
1985 Volvo 245DL "The Silver Bullet "
Old 01-03-2008, 08:25 PM
I used a mini butane torch.
__________________
1996 850 turbo
Old 01-10-2008, 05:54 PM
xpiecemealx's Avatar
xpiecemealx xpiecemealx is offline
Good to know, thank you!
Quote:
ORIGINAL: info2x
Old 03-01-2008, 11:06 PM
andcut andcut is offline
Yeah TECH great job! I wish I had seen this blah blah. Question, what's the point fixing the cable if it's slightly rounded out in the hole that the cable goes into ? would you suggest a dab of that clay metal in there / also how did you trim the cable to make square mine was way rounded and prbably have to trim an inch off of it?
Old 03-02-2008, 06:56 AM
I didn't trim any at all I just heated the metal sleeve and slid it in further.
If it is really stretched you can do both sides and get about 1/4 of an inch or a little more.
__________________
1996 850 turbo
Old 03-26-2008, 11:20 PM
pittpan2005 pittpan2005 is offline
My passengers seat does not stay up, without my homeade quick fix of 5 quarters stacked on both sides of the seat joint. Is that the same cable or a different one from this post? I know its a cable thats causing the seat to no longer lock. It just falls back if not proppedup.
Old 03-27-2008, 06:40 PM
It reclines correct?
If so then yes that is the cable.
__________________
1996 850 turbo
Old 03-27-2008, 11:08 PM
tech,
yes it reclines. It stays reclined unless I pick it up and jam the neck rest against the roof, then it stays up.
Luke
Tags
240, 850, back, cable, connectors, diagnostic, leather, power, repair, rest, seat, underhood, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
© Internet Brands, Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
