keyless lock no more blinking lights
Old May 26, 2005 | 04:04 AM
czr1's Avatar
Default keyless lock no more blinking lights
I lock my car s60 with the remote like always do and don't get the blinking lights anymore anybody know how to fix my problem? also always wondered if there was any way to make the horn sound when locking the car?
Old May 26, 2005 | 12:54 PM
Default RE: keyless lock no more blinking lights
You might have an issue with a faulty door lock.I think the horn might be able to be programmed to beep with the arming or disarming.But the dealer will have to program it.
Old May 27, 2005 | 10:29 PM
reg's Avatar
reg
Tech on a C-70 you can not program the horn to sound when you lock the doors. Only the lights flash. I could never find any thing in the owners manual re: horn honking and so I asked the dealer if a program could be loaded/activated and was told "no".
Old May 28, 2005 | 01:29 AM
ORIGINAL: reg
What year is it? There is alot of stuff that can be programmed that they won't tell you about.
Old May 28, 2005 | 10:16 AM
reg's Avatar
reg
2001 c-70.................now you wouldn't think the dealer is leading me on now???? Yeah, right. Tech, I have found that when I speak to the mechanic, in my case, "John", I learn that the service writer is..............well, how can I say it nicely.................well..........I can't so maybe I should quit right here. Do you think the horn can be programmed??? I do know that I have all the computer updates.......................
Old May 28, 2005 | 02:05 PM
I will try to check into it exactly for you and let you know.
I know on alot of the cars they are preprogrammed for a lot of things.And they are just turned off.
Some are even setup for motion sensors.You would have to add the sensors them selves but the system is setup for it.
Old May 28, 2005 | 05:14 PM
reg's Avatar
reg
Tech, what are motion sensors..............something for the alarm system?? Incidently I installed the reverse radar that installs in the rear bumper.............works very well. I got tired of painting the rear bumper....................you cannot see past the rear window when inside a C-70................of course now for that horrible blind spot in the C pillar.......................
Old May 29, 2005 | 02:29 PM
I know the feeling about the C-Pillar.
Motion sensors are mounted inside the car so that if they somehow break the window and get in as soon as they were in there the alarm would go off.
Almost like the motion sensor lights people have outside their houses.
Old May 29, 2005 | 03:26 PM
reg's Avatar
reg
Gotcha. Age has a way of making one forget................jeez I have motion sensors wired into a couple of my collector autos.....forgot I even installed them!!! I hope you are watching the 500 right now......................
Old May 30, 2005 | 01:08 AM
If you meant the Coca-cola 600 yes it was a good race till the end.
Jimmy Johnson needed to lose.
casualfc
Nov 23, 2009 01:01 PM
gordon368
Jun 6, 2009 03:01 AM
csigrist
Dec 13, 2008 11:48 PM
czr1
Jun 8, 2005 03:34 AM
