brake squeel
Old Jun 8, 2005 | 12:16 AM
lenniefoug's Avatar
Default brake squeel
hi,
I just had new brakes installed on my 98 T-5. Now after approx 1500 miles on them they are making a squeeling noise when braking at low speed or coming to a stop at low speed. Before I go back to the mechanic who did the job, anyone have any ideas or advice on what is going on here. I dont want to BS'd by the mechanic since auto repair is not my specialty.
thanks
Old Jun 8, 2005 | 02:10 AM
Default RE: brake squeel
Are the pads Volvo or Aftermarket?
If they are aftermarket they are to hard of a pad and will squeel till you replace them.
If they are Volvo pads they might not have put enough grease on them when they installed them.
Old Jun 13, 2005 | 11:54 PM
lenniefoug's Avatar
thanks for the advice tech
Old Jun 14, 2005 | 02:56 AM
No problem let us know how you make out.
Old Jun 15, 2005 | 01:29 PM
knight rider's Avatar
I have the same problem with my 850 pads I just installed and it is b/c mine are higher performance pads then stock. I believe that this is common w. performance pads.
Old Jun 27, 2005 | 03:19 PM
lenniefoug's Avatar
Thanks for the follow up advice Knightrider. Any advice is very much appreciated
Old Jun 27, 2005 | 08:54 PM
reg's Avatar
reg
I use after market ceramic pads on the front................they are sprayed liberally with CRC anti squeal..............this product works!! The rears I use are aftermarket and I use synthetic grease on the backs of them. You did not mention whether it is the rears that are squealing or the fronts..................if it is the rears it may well be that the shims were not replaced at the time of new pads.
Caseyglomb
Dec 19, 2013 08:40 AM
v50guy
Jan 30, 2010 11:45 AM
SSN706
Feb 18, 2009 06:58 PM
thullz
Nov 7, 2006 09:25 AM
mywifescar
Jan 13, 2006 12:59 PM
