wierd sound after start up
Old Apr 23, 2008 | 07:47 PM
shelbylay's Avatar
Default wierd sound after start up
I havea 98 S90 and after i start my car in the morning it makes a very loud screeching sound kinda sounding like its coming from the belt. It last for about 10ish minutes or around 2-3 miles. If its cold out( which itnever is in florida) the noise lasts longer. The noise gets louder as i accelerate towards 2k rpms. Please help its very annoying and im sure its an easy fix.
Old Apr 30, 2008 | 10:16 PM
shelbylay's Avatar
Default RE: wierd sound after start up
Anything?
Old May 1, 2008 | 05:32 PM
Has the timing belt and pulleys been replaced lately?
Old May 1, 2008 | 09:50 PM
shelbylay's Avatar
Actually yes,my belt has been. My pulley tensioner broke and the belt popped off when i was doing about 65mphand bent the valves and blah blah blah you know the rest( pretty much blew the head of my car). So ya, its been replaced, and buy a "volvo specialist" (so they say). But this noise seems to be coming from the alternator, maybe my bearings in the alternator are shot? I'm not sure but its very loud and its getting worse. I havn't noticed my battery draining at all so my alternator can't be TOO bad. Any help is greatly appreciated.
Thanks tech.
Old May 1, 2008 | 10:26 PM
If you can when the car is cold remove the Serp. belt and spin the pulleys and try to figure out which one is making the noise.
It isn't the air pump is it?
The air pump is by the battery.
Old Sep 9, 2008 | 03:01 PM
poozit's Avatar
Similiar issue on a 98 V90. Take off the timing belt cover and check the idler pulley for the camshaft belt. It is NOT the same pulley that the tensioner is. It should be to the right of the tension idler. Squirt a little lube into the center of the idler. Don't lube anything else. Start the car and see if that solves your problem. It isn't a permanent fix, but it will isolate the culprit.
neess
Apr 11, 2013 08:39 PM
hitm4n666
Dec 1, 2009 11:06 AM
gatvolvos70
Apr 21, 2006 12:11 AM
frozenbrick
Feb 21, 2006 09:28 PM
knight rider
Jun 1, 2005 01:09 AM
