Won’t Run Right
Old Jan 22, 2004 | 10:05 PM
240GL38751's Avatar
Default Won’t Run Right
I just put a new fuel filter on my 1986 240 Gl. It's like it's a computer limiting it. It won't go over 3,000 rpms, and is real jumpy when it takes off. And when i give it full gas it just stops.
Old Apr 19, 2004 | 05:03 AM
Erock198's Avatar
Sounds like maybe MAF Sensor. Try unplugging it and if the engine smooths out than it is the MAF sensor and needs replacing. Cheap for b230f motors but expensive for b23f motors
Old May 10, 2004 | 09:02 AM
lobwb's Avatar
Hi I noticed a response from EROCK198 's concerning a MAF sensor. I recently broke down on a freeway from Newcastle to Sydney(Australia). Almost 2 weeks ago the mechanic hasn't been able to fix the car. It starts OK and it will rev if you feather the accelerator. As soon as you select drive(it is auto) and touch accelerator it stalls. The mechanic has tried air mass meter/fuel pump, fuel pressure regulator and is now looking at the computer(fuel). Any suggestions? Would EROCK198 receive this also.('86 240 fuel injected)</P>
Regards Wayne </P>
Old May 10, 2004 | 10:20 AM
240GL38751's Avatar
It sounds like the maf to me, but on mine i had the wrong maf on my 240 and it would not runf right maybe that is it.</P>
lagatsby
Aug 30, 2019 07:09 PM
danni
Sep 17, 2013 11:56 AM
waxk
Feb 9, 2004 11:46 PM
danni
Oct 11, 2003 03:56 PM
weppal
May 18, 2003 05:34 AM
