no turn signal and no high beam
Old Oct 2, 2008 | 08:09 AM
reggietre's Avatar
Default no turn signal and no high beam
Hi I am a newbie and have a problem with my turn signals and high beams.
My turn signals won't work and I cannot put high beams on. seems to be a relay. Can somebody give me a diagram of the motor compartment relay box.
Waiting for a reply, thanks
Old Oct 2, 2008 | 09:59 AM
Default RE: no turn signal and no high beam
Also does your wipers only have one speed?
Old Oct 2, 2008 | 12:04 PM
reggietre's Avatar
Thank you Tech for your quick response. You are right I checked and have only one speed on my wipers.
Old Oct 2, 2008 | 03:25 PM
reggietre's Avatar
beeing new in this forum I did not realize that I could do a search on this topic. I did and found one where you mentioned about the steering wheel module and programming. I went to the volvo shop in the next town, he deals only with volvo but is not a dealership. He did a DIM programming and it fixed the problem and the best part is the cost, 55$ + tx. The technician said that it should at 99% take care of it for good. Worst case scenario is that it will need a program package only available at the dealer for about 45$ plus labor at 92$ / hour.
So thanks againtech for pointing me in the right direction. From readingdifferent topics I can see that you know your volvo's. Keep up the goodwork.
reggietre
Old Oct 2, 2008 | 03:57 PM
Glad it is all fixed now.
Old Jun 3, 2009 | 04:01 PM
mrcoleman143's Avatar
hi tech! have same problem on s80 yr 2000 no high beam,one wiper speed and no turn directional indication. hazards work
Old Jun 3, 2009 | 08:47 PM
Default no turn signal,high beam,and one speed wiper
Solved by disconnecting the battery for 5 minutes.I think i got lucky on this one. I guess when in doubt reboot.Worth a try.
Old Jun 3, 2009 | 08:55 PM
Glad it works now!
Old Oct 31, 2009 | 08:04 PM
Cheech's Avatar
Smile Solved!
New member here. Just wanted to thank you all for this thread. I know it is an older one, but I came in here desparately looking this week, because my turn signals, high beams, etc. stopped working on my 2000 S80. Saw the thread about disconnecting the battery for 5 minutes and tried it before I took the car to a dealer, and it worked!! AWESOME!! You guys are the best! I'm hoping this is a permanent fix, but even if it isn't, I was thrilled to be able to get everything working again.
Old Oct 31, 2011 | 10:45 PM
speedracersworld's Avatar
Got the same problem. Will reset/ battery disconnect in the morning. Hope that's it Will post results. Thanks for all the info.
Old Nov 1, 2011 | 07:14 AM
Cheech's Avatar
Speedracersworld, I posted almost 2 years ago, and haven't had the problem ever again, since I did the battery disconnect trick. Just wanted to tell you that when I had my car in at the dealer a few weeks ago for a minor problem, I told the tech that I did that, and he told me that it's fine to do that, but that I should "reset" the system once I rehook the battery, by putting the key in the driver's door lock, and then turning it to lock, unlock, lock, unlock (in that order). That resets everything. Just an extra tip. Good luck - hope it worked!
Old Nov 2, 2011 | 10:35 AM
Thanks Cheech. I did the same thing last night and it worked like a charm I was ready to change the turn signal lever/ module. Glad I decided to search the forum before proceeding. Thanks again to all
Old Nov 3, 2011 | 07:38 AM
Cheech's Avatar
Awesome! It's amazing the little tricks you learn on these forums, from people who've "been there, done that" that save you potential repair costs. I read that there is always a chance that it might happen again, and then you'll have to replace the module if it keeps occurring, but like I said, I haven't had the problem ever again after doing that, and it's been 2 years.
Old Jan 25, 2013 | 01:34 PM
rprcortez's Avatar
Got the same problem. It worked! Thanks
Old Jan 31, 2013 | 07:11 AM
daver80's Avatar
Default turns and highs
Since my deer hit a few weeks ago (hood, all of my front lights, fender, door) I've been piecing my 95 850 GLT wagon back together and noticed that I too don't have turn signals or high beams. Checked all of the bulbs, tried different 15A fuses. Got nothing. Unfortunately that was last night (still waiting for a new radiator to arrive) and today I got a ride to work. SO I will have to try this little trick tonight, see if the magic will work for me too. Sounds like I'm not alone on this one...
Old Apr 16, 2015 | 04:21 PM
Kitezen's Avatar
Thank you, disconnected battery made my daughters and my day. Lights and signals work now.
suckonthiscaravan
Dec 5, 2018 03:19 PM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
mikedooley
Mar 12, 2007 10:12 AM
